car won't hold idle (searched)
scotttak
Car: 2018 Camaro ZL1
all right, ive searched a ton but couldnt find anything exactly like my problem. my car won't hold idle unless a) its warmed up or b) i unplug the maf harness. this happened after i installed my turbo, so i don't know what to do .......any help would be appreciated. im gonna go eat an ice cream sandwich now.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
have you checked for boost leaks?
scotttak
i just searched for leaks, i think i have a small one on my cold pipe. vacuum is reading like17 so its low. cant find the exact site of the boost leak.
scotttak
ok i fixed the leaks. but i still cant idle well. i dont know what it could be. my afr's are all over the place at idle ranging from high 13 to 16 and stuff. ive removed the aiv and blocked of the egr tube. also, i lost the ground wire that ran to my exhaust. please help, ive been stuck like this for days1!!!!11!!
Bwana
Car: Denali
Have you checked the ecu for codes? o2 sensor or wiring could be a possibility.
scotttak
just checked the o2 sensor, its not that. when i unplug the maf, it idles steadily. i think ill go check to see if some codes have been thrown
Bwana
Car: Denali
Bad MAF/MAF plug could easily cause the problem.
scotttak
everything was running fine before installed turbo. but right now im throwing codes 12 which is the airflow circuit, but i was messing around with that so im gonna disregard it, and 35, the egt circuit.
Bwana
Car: Denali
Did unplugging the MAF solve the idle problem?
scotttak
yes it did
Bwana
Car: Denali
Then I'd suspect that either your MAF is shot or the plug is.
scotttak
seriously?? ooooh nooo. i dont have money to buy another maf.
Bwana
Car: Denali
What MAF are you running?
scotttak
stock 240sx maf
Bwana
Car: Denali
You could check the plug and connection first, to make sure the problem isn't in there. I can't remember if SOHC and DOHC MAF's are interchangeable, but I have a good SOHC MAF laying around.
scotttak
i think ill try and check that right now.
scotttak
i dont know....i think my maf is fine because it worked perfectly before i installed the turbo. on my afc i see the airflow meter bouncing between like 1.5 and 2.5 percent in sync with my idle.
scotttak
somebody please help!!!!! please master mechanics, i need your power!!!!!!!
scotttak
would a really small vacuum leak, like a one hg/mm leak cause me to stumble a lot???
scotttak
bump
Bwana
Car: Denali
I'm really not sure what to tell ya man, so I'm going to move this over to the ka-t forum and see if the regulars there can help you out.
scotttak
sweet. thx
adrianfromthecastle
Car: 1992 Nissan 240sx
scotttak wrote:sweet. thx
swap out your mafs with david's or someone else's to see if it will hold idle. and no, iirc dohc and sohc's are not interchageable
scotttak
nah it wasnt the maf...i wonder what it could be??? maybe i need new spark plugs??? im running bosch platinum 4's which suck.
Bwana
Car: Denali
scotttak wrote:nah it wasnt the maf...i wonder what it could be??? maybe i need new spark plugs??? im running bosch platinum 4's which suck.
Critical info!!! Before we throw ideas at this problem any longer, put some real plugs in it. Bosch plugs will screw with a motor like nothing else.
scotttak
im gonna go ngk cuz i know those are good plugs. the question is, which ones should i get??? (don't have a lot of money)
Bwana
Car: Denali
NGKs are the factory oem plug for Nissan engines. Just go to the parts store and give them the year make model etc and tell them you want NGK.
scotttak
should i get colder plugs???? like bkr7e or bkr6e??
GEO
Car: 95 240sx KA-T
get the 7's. 2 steps colder then stock.
scotttak
ahhh too late. i already bought the 6's.
