U12 2NR »
https://forums.nicoclub.com/u12-2nr-u5979.html
Sat Jul 05, 2003 2:27 pm
I doubt the transmission "wore out". These trannies just needs a little extra attention. For example, the cooling tank in the radiator doesn't have fins to help cool the fluid better, which means if you add a transmission cooler you'd be a hell of alot safer. The fluid needs to be flushed accordingly. Alot of people neglect to change their coolant, and when coolant loses it's effeciency, the transmission fluid is also affected. I'd say nissan could have been insightful to these very simple problems and taken preventative measures.
joes240, Check your transmission fluid level. Usually when the transmission is about to go out you'll defnitely get some warning signs. For it to go out all of a sudden without warning is a little weird.
