evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Apr 03, 2008 3:30 am
I am prettysure the master diameter is the same, and what I mean by leaks back is when you ahve someone push and hold the pedal the fork moves, does it stay put or does it start to sink back after a minute or 2, also is the clevis properly adjusted at the clutch pedal? it should have only a very small amount of freeplay before it engages, did you have the fork properly engaged tot he throwout collar when you installed the trans?
