I have a 1995 S14, (sr20). Its running an AEM series 2 EMS (map based) forged pistons and rods (standard CR), BC 264 cams, nismo 740 injectors, straight through exhaust, 340lph fuel pump with a fuelab regulator set to base pressure and a topmount turbo setup with a GT3076 amongst other things.
The problem i have is I can only get the car to idle well at 13:1 AFR and below, as soon as i pull fuel to aim for 14.7:1 it starts to misfire and hunt around, the afr's and vaccum then start swinging around all over the place. If i richen it up it idles really smooth at 850rpm.
What could be causing this? I have done all the usual checks, boost leak check etc and found nothing wrong.Any help would be appreciated.
Thanks
Rob
