hebcz00 »
https://forums.nicoclub.com/hebcz00-u244601.html
Sat Dec 13, 2014 12:49 pm
I have a 2006 M45 which is new to me. Purchased from my brother in Florida about a month ago. I noticed the battery seemed weak and I needed to charge it the other day after the car had sat about 9 days without being driven. The interior lights were weak, NAV would blink on and then fade out. Engine would not turnover. I charged for 4 hours and then it started right up, fully energized. I figured the battery was shot/old and that it didn't have the strength in the cooler Maryland winter, which is where I live. Therefore I had the battery replaced yesterday. Car started fine after I picked it up at the shop and did errands requiring four start and stops over a period of 4 hours yesterday, no problem. Parked in garage last night and now it won't start this morning. (Pushing on brake and start button) The car energizes, all interior lights go on, NAV lights up, radio, car lights, etc. seem to be working. The battery shows 12.75 volts across terminals. I hooked to charger wondering if perhaps the battery was weak/not fully charged. After 6 hours still no turnover. Again all lights, accessories appear to energize fine. I believe the car battery is fully charged. Confirmed battery terminals are clean and tight, no visible corrosion. The FOB appears to be being recognized by car as it will not move from "Lock" to "Acc" and "On" unless I have the FOB in the car. Also the car worked fine yesterday after the battery was replaced. Would would appreciate any suggestions on possible solves or tests to confirm the issue, otherwise I will need to get it towed on Monday to a local garage. Thanks.
