car will not start, running out of ideas, please help
chmercer
ok, i was adjusting my headlights one night, so i had the high beams on, and i forgot about it and they were on for like 30 minutes. Car wont start, it dosent even try to crank, i get a click from the fuse box as i turn the key halfway though start, and a 2nd click when i have the key all the way on start. no other noises.
here is what i have done -
- checked fuses- charged battery, changed out battery with one that i know functions correctly- changed starter motor
what else can i do? all the electronics work like out of the factory; all i get is the prediscribed clicks from the fuse box. please help :(
edit - also, i plugged in the starter and screwed on the negative terminal and had somone start the car, the gear didnt move so i dont think any power is getting to it. but i know the battery is good, so what could be going wrong in between there?
zachosz
Car: NONE!!!
did you double check the connections to the starter? the clicks are probably your electrical system turning on and off, i don't think it's related. double check all the fuses, in the kickpanel and inside the engine compartment, as well as your connections to the starter. It sounds like a simple electrical problem, finding where it's at is a pain in the a$$ though. Good luck.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
is your car a manual or automatic? if its manual, maybe something with the clutch safety switch got messed up? I dunno, just an idea.
chmercer
its manual, also i have sanded down the battery terminals, didnt fix anything.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
does it push-start?
PUSHER
yes, it push-starts
chmercer
also hooked up the starter to the battery so i know 100% it works and i know the battery 100% works so i guess power isnt getting to the starter somehow.. hrm
revhard05
when you hook the starter to the battery dos the starter turn over???
chmercer
yep, battery works and starter works, and battery cable is getting power (got some sparks out of it) so either its a bad ground (which i doubt since i bolted it down as much as i could) or somthing is wrong with the signal wire / ignition switch. any ideas?
driftn240
Car: umm, cars, computers, car audio
Check the under hood relays. make sure that their ingaging(clicking).
chmercer
gave up and took it to the shop, it was the ignition switch :p
driftn240
figures, the last thing to be checked. glad ta hear it's fixed tho.
