WONit »
https://forums.nicoclub.com/wonit-u23073.html
Thu Feb 21, 2008 7:55 am
As the title says my car will not start..I have read all other "will not start "posts..some info,,,89' hatch w/sr20det... Car ran fine when engine was pulled...pulled it out to get head work done to it...
Got the work done.valve job,cams,springs,the works basically..engine is back in car everything hooked up. HAS spark, HAS fuel(atleast to rail),Cranks!
timing is dead nuts on,spark it strong...seems to crank a little slow,almost like dragging,but definaltly fast enough to start.like i said a little slow cranking.even with jump box hooked up,and the battery is fairly new... so far from all the reading i have done,i have gotten this from it..
1-Unplug MAF connector and try to start2-Clean MAF connector and try to start3-Check injector clips,clean if needed4-Check CAS and make sure it is set properly5-Check to see if injectors are firing properly
I just want to know if there is anything else i am missing,as i will not be close to a computer for the next day or so.I would like to add anything else that may be helpful to my list of things to check. thanks in advance.
WONit
