r3v_v3ng3 wrote:crank position sensor maybe? does your rpm moves when trying to crank it?
also how long has this problem occured? did you just turboed your car and can't get it started or you had it turboed for awhile now
I don't know much about about the crank position sensor. How would I know if it is bad? The rpm's do not move when I am cranking it.
WDRacing wrote:I dont have any Nistune experience...is the MAF set for the N60? Is there a base map with Nistune?
WD
There is no N60 MAF in Nistune, which was really disappointing to learn. Although there is a "J30-VG30E (300 HP)" option which I figured would be the closest to the N60.
thanks for your help again guys...
