above140 »
https://forums.nicoclub.com/above140-u42653.html
Sat Mar 10, 2007 1:37 pm
Well I am sorry for having to make this kind of post, I have done alot of engine swaps but I can not figure this problem out, maybe you all can help out:bash . The car is a 91 240 , I took out the engine because it was blown and replaced with a rebuilt one. I try to start it up and it turns over great but will not fire. I have checked timing,spark,fuel,compression, relays/fuses. (Timing) checked and it is correct. (Spark) I checked spark at all plugs and at coil and all sparked. (Fuel) I hear pump prime, When I pull plugs they smell of gas, and took line off at the rail and fuel came out. (Compression) Did compression test and was fine, also if you plug cylinder with finger you feel it. (Relays) replaced the egi and egi pump relay. (Fuses) checked all fuses under hood and at kick panel. I looked over my harness and did not see any missed grounds etc. If I can remember correctly, 2 at the battery/relaybox(not includeing the neg bat cable), one at front of valvecover, and one at back right side of valvecover. I don't have a clue where to go with it now im stumped. If anyone has any insight etc pls respond.
ThanksAndy
