Toshima »
https://forums.nicoclub.com/toshima-u36509.html
Fri Apr 28, 2006 8:56 am
The tic tic tic noise you are hearing is a relay bounceing. First clean the battary terminals real good. If that dont work take your starter off and go have it checked at auto zone its free, and its only 2 bolts and about 5 min of your time. If your starter is ok then if its a 5 speed it could be the clutch interlock relay its on the passanger side inbetween the fender and battary. It could also be the clutch switch that under the clutch pedel that tells the car that you have the clutch down when you start it. Thats all I can think of right now. Oh do you have a aftermarket deck? Could be someone cut the igition wire(under the dash) and just twisted them back togather and they finally just came lose(happened to me when someone else installed a radio before I bought it).
