fat3oy »
https://forums.nicoclub.com/fat3oy-u190004.html
Mon Mar 30, 2015 2:00 am
honda battery prolly doesnt have enough start up voltage to get the starter going - does the "depress brake" animation come on on the dash? what happens when you try to start? click? or nothing? check your dimmer switch for dash lights to rule that out - but sound like the main fuse link maybe... hard to diagnose over forum... rule shiz out one by one
Thinks to check:
fuse link from battery
battery with enough startup voltage
ground to alternator
fuses in kick and hood
vehicle theft system (key battery etc.)
If clicks - check spark, check fuel
check transmission ground, and all chassis grounds for nice white crud buildup - being on the ocean jacks em up... bad ground make all sorts of s*** weird.
