Car will not start but it cranks, when push started it ran fine.
dualn1exhaust
Car: 1991 240SX LE fastback
So I did the diagnosis. You basically need spark, fuel and air to start the car and make it run. When I push started it, it ran perfectly no bogging what so ever.
When I cranked the engine and checked for spark, I got spark from all 4 cylinders.
I'm not too familiar with the 240SX ignition system. Might it be the ignition module?
When I cranked it again to check for fuel pressure, the line didn't firm up at all. So I disconnected the fuel line from the fuel filter and cranked it, no fuel came out at all.
When I turned my car to ON position in the ignition, I can't hear the fuel pump like I used to hear it buzz. Fuel pump must be bad, so I bought a new one.
I need help to start my car up.
Modified by dualn1exhaust at 9:00 PM 7/14/2008
dualn1exhaust
What else could be wrong with my car cept the fuel pump?
driftnslide1
Car: 92' 240sx coupe/ 87' toyota supra turbo
i didnt see there if you checked your relays.
dualn1exhaust
Relays? Is that the fuse box under the hood near the battery? Sorry... I don't know where it is located and what it is. How do I check if it's bad? When I pulled the relay, it looks normal. I dunno what to look for.
Modified by dualn1exhaust at 10:25 PM 7/14/2008
dualn1exhaust
Ok, pretty sure It's the fuel pump since I don't hear it buzz when I turn the ignition ON. So I already replaced the Relay and Fuse. Now, I ordered a Walbro fuel pump for replacement. If this doesn't fix it, I don't know what else I can do.
dualn1exhaust
Do 240SX's have a FUEL SAFETY SWITCH? If they do, where is it located?
