car will not go past 4000 rpms
neverlift
ok I searched ALOT.... its a ka24de~t all was fine till I got a jump the other day, after that it would not rev past 4000 rpms, it will if you 10% throttle past yes ten.
I read about bad maf but mine is good, its a draw threw, at about 7psi(5psi intake pressure after the 2ish drop from the IC)
any ideas?
nwmrkt
Car: S13
i was just gonna say MAF,other than that sorry. Ask in tech forum also.
neverlift
yeah I keep wanting to think its the maf, I may just go buy one from upullit, but again I dont think its bad. I'll try it out.
thank you I figured online mechanic woul dbe better but , less traveled
inertiadrft
Car: Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
fuel pump? maybe..
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
try unplugging the maf... and then rev it... you should only be able to hit 2500... so it the maf was bad it wouldnt hit 4000... cuz when they go bad the magic number is 2500... but try cleaning it... see if that helps
DjTravisSW
Car: Nissan 240sx
How's your electrical? Everything running fine other than the revs?
When my alternator was getting ready to die/die I couldn't rev past 4rpms.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
DjTravisSW wrote:How's your electrical? Everything running fine other than the revs?
I also had power problems when my alternator went. I'm not sure if it was 4 tho, its been a while.
neverlift
yeha IMA check it out in the morning at the parts store, IDK wtf is up, this morning the ***** wouldnt start, after firing right up, went to the store, dead. Got a jump drove home cut her off and tried her again damn thing crunk. I pull my battery cables off and kept running(at idle have you)...
its strange, I can low throttle it past 4000rpm, but wot is a wall of stop at 4k...
S13xCrazy
neverlift wrote:yeha IMA check it out in the morning at the parts store, IDK wtf is up, this morning the ***** wouldnt start, after firing right up, went to the store, dead. Got a jump drove home cut her off and tried her again damn thing crunk. I pull my battery cables off and kept running(at idle have you)...
hmm...the starting problem makes me think its really the alternator.
But off that, i asked in ur other thread but you never answered, are you running anything for tuning? Bigger injectors? still stock fuel pump?
Haha. sorry for thread jack.
neverlift
I did respond
neverlift wrote:
its tuned using a stanza ecu and sohc ka maf, the fuel pump is a walbro, and the base fuel pressure is at 58.9 psi..
from that threadit was running so amazing then I got a jump and it died kinda, the tuen was damn near perfect, and I did it blind for the most part, a few areas needed more fuel, but it was fvckin on, had well over 200 miles on it. I did find a wire getting I believe it to bet to the maf, so I may have fuct the ecu, or maf but my other one was blown.... junk yard in the morning.. ghey any more ideas nico I know if its common you guys know...
Ktt88
Car: 1995 Nissan 240sx
did you end up finding a solution to this.
Im having a very similar problem (pretty much the exact same problem). If come to a dead end, not sure what could be my issue.
Hijacker
Car: '92 240sx Convertible
'94 F-150
This thread is 7 years old, and the OP hasn't regularly posted in 2 years. I would consider checking your MAF if you have a multimeter. The factory service manual has all the voltage readings to verify correct operation.
