car will not fire up need help
Justicc86
Car: anything to do with cars
Alright here is the deal. I got my sr installed in my car, it is a red top in a s14 body (95). Wired the ecu according to sr20.hybirds, all wires are pluged in as far as I can tell and I have: fuel(pulled fuel injector and all spray), spark(pulled all spark plugs and hooked coil packs up and grounded plugs all spark), air(can feel air geting sucked into throttlebody and coming out of spark plug holes), and timing(set top dead center according to heavythrottle website). Motor will not fire up at all, also the starter works fine I am at a loss the only thing I can think of is the wiring has to be wrong or I must be missing a ground or somthing. Please let me know if any of you have any ideas or wiring diagram on what to do or try.
thanks, Chris :confused:
slw240sx
Car: 1990 Ca18det 240sx Hatch
did you hook up the harness under the dash.. i dont know how many times i unplugged it and then went to show off the motor ran and couldnt get it running and spent hours trouble shooting only to have a friend drop in and ask me about this plug by the ECu and i would then proceed to bang my head into the wall
Justicc86
yes that is pluged in :)
yellow_jacket
Car: 95 240sx
I am not that familiar with the cas on that motor, but can you rotate it 180?
Justicc86
problem fixed the timing ended up being way off when we tried to fix it the first time
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
nice! you dont have any pictures do yah?
Justicc86
hopefuly soon pics will be takenmaybe this weekend I can take it to the track big import race at local drag strip
the_invisible
Hey Chris, I am also going to put in a s13 motor into my 95 240sx. What intercooler are you using?
Are you using the one off of the s13?
Justicc86
the stock side mountthat is what im trying toget installed tonight
