Car was attacked when parked. Need help getting a dent out!
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
Dire91 wrote:Test if this works out, I saw this years ago and always wondered.
http://www.metacafe.com/watch/501379/re ... airduster/
Ah man, f*** that s***! I just went and picked up that air duster (compressed air), and done all that s*** on small a** dents/larger dents, and nothing happened. . . It's still the same. That was a waste of my time, seriously.
I also talked to a buddy while I was doing it, and he said he tried it a long time ago, and it didn't work. GAY!
Busey
Gcustoms wrote:so i found out who it was, it was 2 people one of them i actually chill with alot and i had no idea they had a problem with me, or the car.
kicking their asses would end badly because with my luck i'd end up getting charged and theyd get to walk away
and reporting them to the police would just protect them from any real consequences. has anybody had this happen to them? if so what action did you take?
Sugar is your friend...if anybody would ever touch my car it would be 10 fold for them.
Skyline_BNR34
Car: 2003 Nissan Sentra SE-R Spec-V
You could always do it a proper way, but it requires a welder, rivet, and a grinder.
Saw this on David Stacey's show.
Drill a hole or two into the dent, maybe just one and weld a rivet to the hole, and then use some sort of force to pull on the rivet and pop the dent out, then proceed to grind the weld and rivet away, but assuming you don't have any of that it would be quite hard to do.
Do it the cheap way and fill it completely with bondo, or get overfenders.
And sugar in the gas tank does nothing. Mythbusters proved it did nothing to the engine.
