i tried that but i cant get the rpms stable they just want to jump aroundWoods Crasher wrote:Try to pump the throttle a bit to get the revs up with out stalling. And try to hold at at like 1500 - 2000 for about a minute......sounds like the classic cold start issue to me
they are vacuum bridges. as long as you have vac hooked up to your fpr and butterflies back ther you are fine for now with them diconected. also vacuum to the wastegate actuator and bov if you have one.ilovecoupes wrote:Okay I finally got my CA started but affter about 2 second of ideling the car stalls and dies. Except for the 4 metal lines on the intake manifold, i don't know what is supposed to be ran to them. I got a BOV off of my friends DSM, don't know if that could be a problem. could this problem be do to a bad relay i.e. EGI?
Thanks in advance
you check for fuel pressure with a fuel pressure gauge.ilovecoupes wrote:I don't think its leaking air. and how do i check for fuel pressure, because i hear the fuel pump's humm. And to keep it running i have to romp on the gas and still is stumbles and dies. It feels like i have a giant vaccum leak, but there isn't one!
oh, and at the moment im not running an o2 sensor cause my swap didn't come with one. I said a fuse because my egi fuse was buzzing but went away. Anything else?
thats not true during startup up.only after the car come up to operating temp and goes into losed loop.Zero260 wrote:if you don't have an o2 sensor on there the computer is going to run in limp mode, and dump extra fuel into the cylinders, that is likely your problem. and the metal lines on the intake, if they're not hooked up, are they atleast plugged off?
im an idotca18datsun510 wrote:you check for fuel pressure with a fuel pressure gauge.
you mean unplug the big hose for the brake boster than clog it up with a bolt or somethingca18datsun510 wrote:check your brake booster. disconect the vac line and plug it up.
so plug up all of the four metal lines on the side of the manifold.jiggy180 wrote:The 4 metal lines between the intake runners are for vacuum hoses that go to the Butterfly control stuff (Tank, valves etc.). If you arent running the OEM setup then you should plug 'em up as they will cause you a vacuum leak.
im pretty sure i don't cause i switched them and then my car wouldn't start at allca18datsun510 wrote:do you have your fuel lines mixed up?
yes...any vacuum port not used plug it up or the car won't run. Run down to your auto parts store and get vacuum caps for them.ilovecoupes wrote:so plug up all of the four metal lines on the side of the manifold.
If you havent download a CA Factory Service Manual, i'd probably get one ASAP! That and a copy of the Nissan FAST version of it too. These two sources should have most if not all your answers!ilovecoupes wrote:can anyone tell me about the pressure regulator solenoid valve think this could be the problem?
