chinadan wrote:...road tests are sifficult to come by, so they mostly do balancing.
I hope you didn't misunderstand me when I called it "Road Test" balancing. They don't actually drive your car. It's just a better machine method that many tire shops offer now. Here is an explanation of what I meant (this was cut from another article):
One of the best methods available today is called road or radial force variation balancing. This requires the use of a special balancing machine equipped with a roller on a robotic arm whose purpose is to exert rolling force onto the tire/wheel assembly. What this equipment does is measure how round the tire and wheel are under a true load. The data collected from the test is valuable because sometimes a tire may be “out of round” and still appear to be perfect. Once the machine determines the high spot (section of the tire that exerts the most force on the road) it digitally recommends an index position of the tire in relation to the wheel. Basically it tells the mechanic to spin the tire on the rim until the highest spot on the tire is even with the lowest spot on the rims run-out.
