1991S13 »
https://forums.nicoclub.com/1991s13-u22320.html
Tue Mar 29, 2005 5:22 pm
Is it coming from the driveshaft?
Pull the back half of the driveshaft off and see if it goes away. If not, pull the other half of the shaft off and see if that eliminates it. If so, I would either try balancing the driveshaft, or changing the carrier bearing.
If the vibration still happens, atleast you eliminated the driveshaft being a possibility. It could either be in the transmission or rear.
I fought with this same thing for a couple of days. Turns out it was the carrier bearing.
