AmoebAssassin »
https://forums.nicoclub.com/amoebassassin-u22213.html
Tue Jan 09, 2007 1:46 pm
Thrust angle is the angle between the lengthwise axis of the car, and the angle at which the engine's torque is applied to the ground.
It could be your alignment -- if you have positive toe on one of the rear wheels and negative toe on the other, you have changed your thrust angle and the car will behave EXACTLY as you describe. Alignment is the easiest thing to fix, and should be the first thing you check.
If you check, and both your wheels are equally toed in, or neutral, then chances are your subframe bushings are shot, which is allowing your subframe's lengthwise axis to be nonparallel with your car's lengthwise axis, changing your thrust angle when your subframe shifts.
**EDIT** Found an image:
