CAR TURNS ON BY ITSELF?!?!?!?!
Post all your Nissan electronics, car audio and stereo questions here!
XxXSnake23XxX
Car: 2007 Nissan Altima 2.5S CVT
I have a 2007 altima and i just installed a Viper 7900.Today when i was out the car turned on by itself while the transponder unit was off, upstairs in my room. What is going on???Thank you very much!
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Your remote start is in timer mode. Not to sure on how the remotes on this one are programed as I haven't played with it, but I know that the older ones if you pressed the lock and unlock button it put it into timer mode (every 6 hours or something like that) instead of the * twice that would just remote start it once.
XxXSnake23XxX
how would you disable "timer mode:... on the older ones?
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
I honestly don't remember. Did they give you a manual with the starter?
XxXSnake23XxX
to exit timer modea. With engine off, turn the ignition to the on position.b. Step on the brakec. Open the hoodd. Toggle the shutdown switch to offThe lights will flash four times to confirm timer mode has beenexited.
what is the shutdown switch??
Modified by XxXSnake23XxX at 10:38 AM 2/18/2008
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
IF you have it (I rarely installed them because it it lead to was customers coming in with "my car won't start" it will be onder the dash. it's just a toggle switch that says on and off on it. If it's not to hard I'd go talk to the installer.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Did you end up getting this worked out?
