car turns off while im driving...
qqNISMO240pp
Car: 1992 240sx s13 - 1993 240sx s13
i have a 1992 240sx stick stock, if im in 3rd gear or any higher and if im driving and i hold down the clutch the rpms drop down really fast down to 0 and shuts off. anybody knows what that is or is that normal for these cars??
theengineguy
Car: 1995 240sx se
no thats not normal in any car, i recomand you get a can of carb spray and clean your throttle body first, if that doesnt change anything let me know and we'll go from there
qqNISMO240pp
didnt work
qqNISMO240pp
anybody else have any ideas?? please help
nissan_star
Car: 2000 maxima se and 1993 240sx vert (5sp!!!)
try just idle. If it slowly dies trying to idle check your vacuum lines (specificaly the big one on top of the firewall by the windshield)
check vac. lines anyway really
qqNISMO240pp
it idles great around 700rpms. its only when im driving. as soon as i put my foot on the clutch the rpms down to 500 then to 0. every time. the hoses are all new and intact. it does it when im in 3rd gear or higher.
qqNISMO240pp
hey every one I FIXED IT ahaah it was actually quit easy just over looked it. i had to plug the pair valve hose. i removed the pair valve but never plug the hole. i also had to plug the hole going to the pair valve coming from the intake. also had to plug the hole under the intake next to the throttle body. and had to replaced the fuel pump fuse. so if anyone is having this problem i hope this helps.
xletitride4lifex
good stuff i had that problem but it was my little idle screw and all i did was adjust it a little and it stopped doing it, like it ran but when you put in the clutch it bogged down and stopped running.
driftneil
Car: A pile of cars.
qqNISMO240pp wrote:hey every one I FIXED IT ahaah it was actually quit easy just over looked it. i had to plug the pair valve hose. i removed the pair valve but never plug the hole. i also had to plug the hole going to the pair valve coming from the intake. also had to plug the hole under the intake next to the throttle body. and had to replaced the fuel pump fuse. so if anyone is having this problem i hope this helps.
Why did you have to replace the fuel pump fuse?
qqNISMO240pp
it went bad. and wasnt workin right
driftneil
So that obviously means there is something more, then just the fuse. They just dont go bad, they are forced to blow.
qqNISMO240pp
i changed the fuel pump also, everything is goin good so far
