!!!80 bux, dam! i thought i picked one of those up for like 20 from oreily's a few years back, mebe im smoking crack or something.... definately time to upgrade the coil if its 80bux for a stock replacement... if you dont want to spend $$ right away why not go get a 2$ coil from the junkyard and try it out first (temp solution...) if not, a blaster coil'd be a good idear anywaysAtown 240 wrote:
I called Napa and they said a new coil pack is $80!
I'm going to pick up a Blaster 2 coil and try it.
Thanks for the additional info.240on430 wrote:Before I changed my fuel pump may car randomly dies under load.
Since you don't have spark...it's not your fuel pump.
Just thought I'd throw that out for people that are reading.
I dont think so, i dont see how any wires could have gotten stripped.OldmanPurdy wrote: Its definatly electrical. I have/had the exact same problem as you a few weeks ago, the engine would just shut off randomly while driving everything else works just the engine won't spark and it would take like 10-15 miniutes before it would go again. I replaced the coil, but the problem was a short, in the wires going to my e-fan. Since you mentioned a rebuild, any chance some wires could have had the coating stripped off?
Alright thanks, It seems like i might be mising one but i dont think i ever had it. It's the Ignition Coil one. Here is a pic.DjPantsSpecR wrote:you can easily see by putting in a different/new battery if the alternator is really your problem. you can drive your car for about three days with no alternator on a full charge. i drove for a week with some spare batteries in back for when the one up front would die. a dead alternator wont show up until you see the battery dead.
so you're definately looking in the wrong spot. i said what i said before because i had a short in my e-fan wiring jsut liek the other guy.
you blow the ignition sw fuse. big green fuse on the passenger side panel in the bay. did you check that yet? it can look good, and be blown, so take it out and shake it to see if there is a break.
but check all those fuses, if you blow an alternator fuse it'll seem like a blown alt, adn then the abtt will eventually die. the car runns worse and worse for about an hour before it dies, you would have noticed. it doesnt just all shut off.
i just helped someone else who had this problem, and the short wasn't in their e-fan wiring, it was in some of the stock wiring.
so check all those fuses, then you'll probably look for a short, and yes they do just sort of show up.
