ok I have read over the document several times (section 12)However im more of a picture sort of guy at this point with the Q and am having a hard time understanding what exactly I should be doing (And it says there are digital photo's to every step but I've found this document in several places and none have pictures execpt one you can download has pictures to the butterfly clips, one had a picture of the fuel pump an o ring and the FPCU)
wrote:- Inspect the wiring everywhere; notice any charred or burned areas(my ground wire on the bottom right (terminal side, tab on top) of thewhite male fuel pump control unit connector was charred a bit.
Now I get this part (only because of the tab on top part) - however the only cable I was able to observe was one that split between the FP and FPCU (blue ends). Without a picture to circle im not sure if that's the one we are talking about or not
Anyways about grounding it, im going to grab an alligator clip cable and connect it from what exactly to what? Just shave off some of the cover on the white wire and clip that to any metal part of the FP? Or clip it to the cars frame for a ground? Maybe leave the cover off the FPCU and clip to the inside of it where the white wire leads? Too late for me not to sound like an idiot so I might as well be positive of what im doing long before I do it
Thanks again guys, at least there is always light at the end of the tunnel when you have access to NICO
