Car trouble please help!!!
Including IL, IN, KY, TN, MI, and OH
wynnEZ
Car: 90 240 CA POWA!
I recently bought a 90 240sx with a ca swap, I was driving it home from buying it and was doing just fine. I was just cruising and it started bogging and its died on the side of the road. We then babied it home (it was running extremely rich). We got it home put new injectors got a tune with z32 maf and installed an safc. We found out it didn't have a TPS so we got one off a ka throttle body. We started it up and had a horrible vacuum leak, it was reading -11 on the boost gauge. Found one leak and closed it up but didn't run any better, it actually runs better with more leak. What its doing is it does idle but when you give it gas is bogs and bucks.
*If anyone can help me I would be glad to pay for gas and food!*
Engine : CA18DET (48,000)
S15 T-28 TurboStainless Steel Oil LinesGreddy RS BovHKS WastegateHKS Powerflow Air Filter2.5” Turbo Intake3” Megan Downpipe85MM HKS High-Power ExhaustPorted Intake ManifoldJohnny Racecar Large IntercoolerSard FPRZ32 Maf Z32 Maf AdapterKoyo RadiatorArc 1.3 Radiator CapZirgo 14” Electirc Fans On a Heat RelayZ32 Fuel Filter550cc InjectorsWalbro Fuel PumpJun Forged Lightweight FlywheelSpec Stage 3 Six Puck ClutchRelocated Optima RedtopNew OEM Water PumpNew OEM Thermostat
Interior :
AEM Digital Tru-Boost ControllerAEM Oil Pressure GaugeInnovate Wideband with DB gaugeJDM Gauge ClusterJDM Pink bubble shift knobCorbeau Forza Leather Racing Seat with Sliding RailsNismo 5-Point HarnessAfter-Market Steering WheelBoston Acoustic Front SpeakersAlpine Type R Rear SpeakersPioneer CD Deck
Exterior :
Toyota HID ConversionRota D2 17” +32 Offset Rims with Polished LipPignose Front with Upgraded LipNew Spoilerless Rear Hatch
Brakes/Suspension/Ect
Kaaz 1.5 Way LSDKYB Struts with RS*R TI2000 SpringsAftermarket Tension RodsNew Steering BushingsStainless Steel Brakes LinesStainless Steel Clutch Slave Cylinder Line200sx English Full Service Manual
Picture:
CA Forum thread :zerothread/344966
Video:
Thanks for looking!
Wynn
Modified by wynnEZ at 10:12 PM 7/8/2008
Modified by wynnEZ at 11:08 AM 7/9/2008
574-240sx
Car: Nissans, Toyotas, Subaru
Its hard to say but I may have some time. Also what are you using to tune those 550cc injectors down?
Modified by 574-240sx at 5:49 PM 7/13/2008
wynnEZ
I just got my ecu tuned for a z32 maf and 550 injectors. I also have a SAFCII to fine tune later. If you could help out I would be more than glad to pay you for your time, I just need to get this thing running!
574-240sx
Sorry I got really busy this weekend. I will email you my number and give me a call this weekend and I should be able to help.
wynnEZ
Hey no problem, ill shoot you a call this week and we can work out a time. I work on Sat and Sun until 2 but I can get off a little early if that helps you to. What ever works best for you.
Return to “Central Region”
