Just bought a brand new Cat and it even did it when I had my test pipe on.Thanks though.Steve Lloyd wrote:as far as the sputtering and warming up issues, you might be starting to get a clogged catalytic converter. This just recently happened to me, check your exhaust flow at the tailpipe. Have someone slowly rev the motor while you feel for exhaust coming out of the muffler.
Already checked for leaks, Could a bad MAF sensor be doing it. anyone.fast_s13 wrote:check to make sure you dont have a vac leak....check the intake manifold
I cleaned the MAF sensor and it has new plugs in it already, also the spring on the TB is still good it slams closed and thats with the TB cable off.ca18detgabby wrote:the spuddering on the light throttle..........
sounds like a definate dirty maf. would be my first start.
I would also replace my plugs(plugs with carbon build up and/or old will cause a spudder)
for the idle....... sounds like the TB spring is either not recoiling all the way and not closing. they wear out over time.... it happens. let the engine fire up and manual recoil it all the way and see where it idles....
could also be your throttle cable has been set to idle there.... but the prior is more likely.
already replaced both of them!ddgsxr504 wrote:Replace your coolant temp sensor. It's on the intake manifold.
FSM? Is that Fuel system manager. If its that no I don't have one already. I haven't changed the sock yet in the tank but I can give that a try. and I think I will try to get a new cap and rotor and see if that helps. Yeah I already changed the fuel filter and it helped a little. Maybe I need to do the same get a walbro 255 and use it so it will be one less thing when I get my SR20.GoinTopless240 wrote:I'm guessing you did the obvious - changed the fuel filter, but what about the fuel pump sock. I had a similar problem with hesitation when mine was an auto. It's an easy check. First - go to the dealer and get a rubber O-ring that goes to the fuel pump access opening (I think it's about $10, but only available from Nissan). Go to AutoZone and get a Fuel pump sock/filter (like $20). Open trunk/hatch, pull the fuel pump out. The sock is located on the bottom of the pump and can be just pulled off with some pliers. Put the new sock on and put it all back together. Mine gunked up from my car sitting for some time in garage. It would take it some time to act up when driving. I guessed the pump was getting weak from trying to suck against all the rust that was in the sock. I ended up changing my pump to a Walbro 255 cause I knew I was going SR anyway. Just a thought. Many people forget there is a filter back there. On a different note. Have you put a volt meter on the TPS and made sure it was adjusted correctly? I'd have to check the service manual for the correct voltage, but I'm sure someone here knows it off their head. I'll see if I can scan the pages this weekend for ya, unless you have an FSM already. Let me know. I actually have one for the KA24E motor (89').
