40oz »
https://forums.nicoclub.com/40oz-u117556.html
Tue Feb 03, 2009 8:20 pm
i put in a newer dizzy but neglected to make sure it was at TDC before pulling the distributor out, i then started the car afterwards and it ran rough. then i pulled the dizzy out, realigned crank pulley so the pin is at TDC, and the rotor is facing #1 cylinder. also checked for TDC on compression end with the screwdriver trick. it ran completely fine before i took the distributor out. now it won't turn over, it turned over a bit once but now it sounds like its struggling to get turned over. to be clear it IS trying to turn over though. i am getting fuel and spark but there were no symptoms of this before the dizzy replacement. also aired it out as to get rid of the flooded fuel too but no luck. Need car running to go to school and work, PLEASE HELP GUYS!!! Any ideas, comments and advice will be greatly appreciated.
