nothing »
https://forums.nicoclub.com/nothing-u70570.html
Tue Apr 28, 2009 6:50 am
You're getting code p1400 (egr and canister control solenoid valve?) and code p0505 (idle malfunction). The egr valve can also greatly disturb the idle. I don't think it would do it to the point where it shuts off though. I would definitely take it out and clean or replace.
The intake air control valve (IACV) can be the culprit for your shutting off problem. I had this same problem on my '94 Mitsubishi Galant. We switched out the throttle position sensor (TPS) and adjusted to spec., cleaned out the throttle body, cleaned out the IACV and finally replaced it for a newer one from a junkyard. Changing out the IACV fixed the problem.
Does anyone know if the IACV has a specific adjustment? I'm sure this answer is in the FSM. But maybe that's the problem.
Good luck.
