Car Symptoms
veritech
Car: 95 240SX KA-T
car keeps stalling at idle.....not sure if its due to the large injectors (550cc) w/ stock fuel pump and safc tune
a/f meter goes between 13.6 - 15.X
any ideas?
GEO
Car: 95 240sx KA-T
Is your blowoff valve loose?
also, do you have the SAFC tuned for an open blow off if you have one?
veritech
Car: 95 240SX KA-T
i dont think it is ill check it when i get home
where do i go to check if its tuned for an open or recirc b.o.v?
480sx
Car: 1996 Pearl White 240sx
Hes saying he has stalling problems at idle.. So things like decel settings arnt really going to do anything for his problem.
OP - You arnt really giving us much information dude, be more specific. Will the car idle at all? Does it stall when you push in the clutch? Just saying it stalls at idle isnt enough for us to really help you. What have you done to try and fix the situation?
Modified by 480sx at 12:48 PM 4/18/2008
GEO
Car: 95 240sx KA-T
480sx wrote:Hes saying he has stalling problems at idle.. So things like decel settings arnt really going to do anything for his problem.
I believe it has to do with him coming to a stop and idling.
j-z
Car: 95 240sx
yeah but we dont know for sure because he wasnt specific at all. would love to help as well but need more info man... have you even driven the car?? hows your maf setup? bov placement?
veritech
Car: 95 240SX KA-T
sorry bout that...well im using a 300zx maf...as far as i know its working fine the last time it was checked....the car stalls after a cold start or coming to a stop as well....itll stay on as long as i give it some gas at a dead stop...my bov is right beneath my intake ill post pics as soon as i can and its not open ventilated its recirc.
j-z
Car: 95 240sx
prob your in/out settings on your afc then.... i forget what mine was at when i was running a z32 maf... 2in/5out or something along the lines. i couldnt get mine to run right with the n62 on 5 out so i ran on 6 out and it worked fine. if you havent done this then thats your prob....
