Car stumbles while cold during acceleration
dysfunction8
Car: 1999 Nissan Sentra XE
I'm new to the board and am looking for some advice. I own a '99 Sentra and for the 2 time ever am having problems with it. After the car has been sitting overnight or for any extended period of time (4+ hours) the car stumbles during acceleration. Once it warms up, the problem seems to disappear, except for once in a while during driving it might fall on its nose for a second, then it's fine. It's not throwing a check engine light, and ive done a basic ignition tune up and replaced the fuel pump. Replacing anything else is going to start getting expensive and I'm quickly running out of cheap ideas. Anything will help. Thanks.
nametakennow
Car: '06 MINI Cooper S
How's your water temp gauge reading?
Sounds like a bad thermostat to me.
Welcome to NICO!
dysfunction8
Temp gauge reads within its normal range. I had someone tell me to check the TPS and CPS as well.....I'll see what autozone can tell me
nametakennow
Both are possible but less likely since it's cold-only.
It can be hard to tell if the thermostat is accurate because the gauge only shows a very vague range, but I figured if it was reading screwy it'd be a tell-tale sign.
Anyway, get the TPS and CPS checked, but if those are fine then go ahead and replace the coolant temp sensor.
dysfunction8
Well, apparently autozone cant test either of those (or so the angry old man tells me anyways), and the coolant temp sensor is a cheap so I'll give it a try in a day or two. I'll let you know.
denver_gxe
Car: 2001 Nissan Sentra
my car did that at the beginnign when the MAF was on its way out. but it only stumbled when cold. when it was warmed up it was fine.
denver_gxe
if you have a dvom i can get you the specs for the maf, along with specs for the other sensors
dysfunction8
I have a multimeter, does that count? It measures voltage and resistance.
nametakennow
Yeah, you could use that to check the sensors. Look up the specs in the FSM (link in my sig) and compare your readings.
denver_gxe
i will post specs in the morning.
dysfunction8
I tested the MAF 1.17 at idle when warm, and I dont have a tach, so i cant really test it at 2500 RPMs. Now, something i forgot to point out is that the car doesn't stumble when idling or when its out of gear and i rev it...It only does it when there's a load put on it.
dysfunction8
Also, the TPS checked out fine. but I'm not sure how much good checking these things are if the motor isnt fumbling and stumbling while im checking them
dysfunction8
Well, I used the Self Diagnosis Program on the ECM, and it gave me a code 0505. So, I think I'm going rack it up to an act of god and wait til something actually breaks on the car so I know what to fix (Since my car says nothing is wrong at all) Maybe I just had some bad gas or something. Thanks for your help guys.
