I guess pause would be a better word. It pauses for half a second under normal acceleration. Under full throttle the rpm's go up as normal. I mean the pause is visible on the tach and you can feel it. I may have to try and record a vid of it.Reverend D wrote:Freeze as in won't go any fast no matter how hard you mash the pedal? Then returns to normal shortly after?
It occasionally throws a code, but it's due to not having a front cat anymore(aftermarket header). I still have not figured it out. I'm wondering if its the tps.Reverend D wrote:Any codes or warning lights on the dash?
