Car stuck in park
jbolton2
Car: 2010 Nissan Versa
I have a 2010 Versa and it will not shift out of park. I can get it to shift with the shift lock feature, but once it is in park it will not shift w/o the shift lock feature, again. Any ideas as to the problem that will not let me shift? Thx for the help.
Rusty45
Car: 2014 Nissan Versa Note SL
Check to see if your brake lights are working. If they arn't check that fuse.
jbolton2
Thanks for the response. However, I already checked the fuse and it's not blown. The taillights are still working, as well. Any other ideas?
AJVersa
Car: 2009 Nissan Versa S Hatchback
The shifter is similar on both the 4sp AT and CVT trans.
Are the "BRAKE LIGHTS" working? If they work, check the shifter solenoid operation. Turn the ignition ON, do not start the engine. Press the brake pedal. Do you hear a "click" sound near the shifter? If you don't look for the Brake Light Switch. Its located near the top of the brake pedal. Check if it's loose. Are the wires secure? Try to operate the switch with a small screwdriver. If you hear the click, you need to adjust the switch.
If you still can't shift normally. Your problem might be the key interlock cable.
Does your shift indicator line lineup correctly? - Park position switch?
Use link for reference.
http://www.nicoclub.com/FSM/Versa/2009_Versa/AT.pdf
Good luck
jbolton2
Thanks for the help AJVersa. Those are some goods suggestions.
