OpenThrottle »
https://forums.nicoclub.com/openthrottle-u70607.html
Fri Jun 20, 2008 6:19 am
Its a 1995 240sx with a s13 SR20DET. Auto to Manual swap. The starting circuit on the side of the fuse box (top connector) has been jumpered. For some reason my starter is not getting any power, all connections are connected on the starter. Fuel pump is priming and I hear the injectors come on. As far as i know the clutch is disengaging. Checked all the fuses, and all are good. Took the starter to get tested today and it passed the test. There is only one relay that seems like its not getting any power and that is the Clutch Interlock Relay. I don't know jack about what the ignitor chip does but I checked it any way (checked both ends while one end being connected and the key in the on position) with a test lamp and the test lamp didn't turn on on either sides of the ignitor chip. I have a J4 ECU and I tried checking for ECU codes but there is no knob to turn for diagnostic mode. The Temp. sensor is not plugged in because there is not a plug on the harness for the sensor. Also, the MAF has not been wired in yet. Could the MAF not being wired in cause the problem? What else could be the issue?
Thanks for the help.
