Car still overheating........
hitlayers
Car: 2001 nissan pathfinder LE
I just changed the radiator in my fiancee's 2001 pathfinder le, filled the reserve and the radiator, ran the heat for about a half hour, car still starting over heating, did I let it circulate long enough? Not sure what I did wrong. Please help. Thanks!
jsm02cpa
Car: 2000 QX4
Did you replace the thermostat? If it is stuck closed, it would cause the engine to overheat, and it has nothing to do with the radiator.
hitlayers
No, but the fan still comes on so I don't think it's the thermostat but it could be, should I just change and if so, where is it? Pictures would help. Just an FYI again this is my fiancees Jeep, I have a 2000 Acura TL which I know all about.....Just wanted to add that so you guys don't think I know nothing about cars............
fueler
Car: 2 Nissan's
2 BMW's
thermostat has nothing to do with fan...
WINNIPEGS_MOST_WANTED
Car: 2003 Nissan Pathfinder
... and if this is for a Jeep why is it in a Pathfinder/QX4 forum?
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
WINNIPEGS_MOST_WANTED wrote:... and if this is for a Jeep why is it in a Pathfinder/QX4 forum?
Some people call all SUV's "Jeeps". This could be the case. Like how some people, especially in the southern states, call all flavours of soda pop "Coke".
http://strangemaps.wordpress.c...a-map/
Pwnin O'Brien
Yeah, it may also be a typo since his username info box thing says 2001 Pathfinder LE and also in his first post he says...
hitlayers wrote:I just changed the radiator in my fiancee's 2001 pathfinder le...
slickroger
Car: 2001 Nissan Pathfinder
The cooling system in your pathfinder is run totally different than your acura.
In your acura the fan comes on when the thermostat tells it too and refilling coolant is done right at the filler neck of the radiator, while running the car with the rad cap off and you constantly filling as air escapes.
In the pathfinder the fan is always on because it is connected to a belt that is constantly running, and filling the coolant properly is a lengthy process if you want to do it right. Your supposed to run the engine rev it at about 3000 for 10secs let it cool then refill the rad and repeat until you cant fill the rad anymore.
I think you have a thermostat problem its not a really hard part to replace
Make sure you get the right thermostat, your most likely going to be given the wrong one first which is for the manual transmission pathfinder. The auto thermostat has a pipe line the manual is missing.
Good luck
hitlayers
Thanks slickroger, and to the other clowns, keep the jokes coming since you have nothing else to do with your life!
jsm02cpa
Car: 2000 QX4
Heck, I just feel bad that you replaced a radiator when it was probably a $5 thermostat! Maybe the radiator needed to be replaced, but general rule is to replace a thermostat when you replace a radiator, just in case.
Good luck, it may be a simple fix.
slickroger
I have already replaced a rad and a thermostat prematurely so i am trying to prevent others from doing so anyone in brampton area need a rad i got one for real cheap if you want it.
Pwnin O'Brien
slickroger wrote:I have already replaced a rad and a thermostat prematurely so i am trying to prevent others from doing so anyone in brampton area need a rad i got one for real cheap if you want it.
I have a somewhat weird question for ya, do you know the dimensions of the finned area of the radiator? I'm looking to do the electric fan conversion and I don't know the radiator dimensions and the max size fans I could mount to it.
slickroger
I have one out so ill do that for you too should be up later tonight sorry i cant do it right now
slickroger
Good luck
Here is the thermostat you want
Pwnin O’Brien wrote:
I have a somewhat weird question for ya, do you know the dimensions of the finned area of the radiator? I'm looking to do the electric fan conversion and I don't know the radiator dimensions and the max size fans I could mount to it.[/QUhttp://images.zeroforum.com/new/1/post.gif
Here is the bare Rad i measured and it was 19 7/8" x 28 1/4"
