worangejuice »
https://forums.nicoclub.com/worangejuice-u33452.html
Wed Jan 17, 2007 1:43 pm
Hi,Searched and Read through a **** load of old threads and replaced a lot of parts. Maybe one of you guys can pinpoint before I spend more money All this happened after I replaced my bumper. Only electrical thing I did was disconnect my headlghts w/o disconnecting battery .
1992 Silvia front 240sxka24de-manual
Symptoms:car willl not turn over,only a click under dash,behind driver headlight,and around fuse box area by battery.dash lights not lighting at all (heater lights went out a long time ago,saw the thread on how to replace these with the white box behind the driver kick panel,but shouldn't affect the start-up).Headlights still work and bright,front turn signals work, but corner lights not lighting up?,cd player works,heater works. Sounds like fuel pump is starting.
So far:Replaced and checked all fuses and relays in kick panel and by battery. Replaced the blue relay on pass. fender.Replaced Starter.Replaced Alternator last monthall theses are new parts.Opened up steering column cover and everything is connected.Black button behind clutch is connecting.Battery is a month old and tested as good.Checked under car and every nook and cranny everything is connected no loose wires.Spark plugs looked good a little burnt but that wouldn't necessarily affect it right?
After checking all the above my car is still not running!!! I've continued to search and found that all that's left is the following:Clutch interlock switch on passenger side footwellCheck,change ignition switch. (funny cause these didn't come up till later,after I changed all the above. )
SO is there anything I've missed besides the last two here? At least if it's only these two then I'll kind of have an electrical tune-up. Thanks in advance!!!It's been a week of the bus and picking up my girlfriend on the bus too
