Broadfield »
https://forums.nicoclub.com/broadfield-u46569.html
Tue Sep 29, 2009 4:21 pm
How often does it cut out? If it's very often then simply pull the radio out of the dash, with the plug still connected, and put a multi-meter or test light on the ignition feed for the radio. Check to see if you lose power on that wire when it cuts out. If not, then you have a bad radio. If you do lose power on that wire then you will want to try to trace the problem down or simply run a new ignition feed to the radio.
