Car stays running after it is turned off
89SilEighty
Car: 89 240sx 54,000 original miles UDP, ported and polished head and intake manifold, removed swirl val
Hi i just remade my screen name i was a member a few years back and have still used this site to find info on parts and mods for my 240 but i ran into something that i cant find in the FAQ.
I have a 89 240sx ka24e exhaust, intake, header, UDP, and electric fan. when i turn my car off it diesels or thats what i thought, until i was just sitting inthere with the radio on and the key in the on position and i turned my car off and took the key out and the dash and sensor lights stay lit for like 3 seconds. So i did this a few more times and i think i have a short or maybe bad grounding but im not sure what would cause this. Any help would be appreciated Thanks, Ben
eastcoastchaos
Car: 95 240sx
did this happen right after you installed your electric fan.i only ask b/c myself and wilfonso have both installed electric fans and had the same problem. mine is wired to the fuel pump and i think his is the same. the only thing i could come up with is that the electric fan continues to spin for a few seconds after the car is shut off and generates power as it spins. there for still running the car. i rewired mine to a switch on the dash and the problem went away.
wilfonzo
Car: s14
its wilfonZo... yeah its true my car does it aswell and ECC's theory sounds pretty good to me... but if this isnt it id like to know why
89SilEighty
Yup i rewired it not to long ago because my thermostat i had on it shorted out, so i rigged it to fuel pump lol and thats exactly what is happening ill change it to a dash switch tomorrow thanks alot i was worried something electrical was wrong.
InsanityInc
Just having it run the fuel pump won't keep your car going. Your computer will be off so your injectors won't even open, much less will you have spark. Not to mention that the inertia of your fan can't generate enough electricity to run a high pressure fuel pump for any measurable amount of time.
Your problem is something else.
89SilEighty
Hmm thats funny i rewired it to a switch inside the car instead of the fuel pump fuse and it doesnt do it anymore guess it wasnt something else!! Thanks for the help guys much appreciated
eastcoastchaos
Car: 95 240sx
awww, sounds like somebody is upset i'm right. maybe not for the right reasons but it is the wiring into the fuel pump that screws it up.
NISTECH
My guess is you guys were wirning to the wrong wire on the relay. If you did that the fan would generate enough voltage to power the fuel pump relay long enough to cause this problem. The ecm should shut down but if your back feeding the circuit for the ignition like that I could see the ecm having enough voltage to continue to hold the ECCS relay closed and power the rest of the system to run. Untill the fan stops spinning. Interesting glitch.
karmakaze
Car: 98 240sx SE
its electrical feedback. move the fan to a circuit thats not connected to the starting/ignition system and and it will go away.
