The vacuum system in our NA's is actually extremely simple, there are really only a few places to check that aren't obvious.
Here's a few that you should check...
The balance tube can be a source of a leak - seems common to accidently put it back on with the wiring loom bracket under the tube instead of over it. instant leak.
Also, the balance tube has a few nipples on it that source leaks.
Another issue is that the diagram above does not include the idle air circuit, which actually sourced one of my leaks, there was an ancient hardened rubber hose that had a crack on the underside, I replaced all of those hoses with Z1 silicone and my vacuum issue was fixed.
