Car starts fine but does not drive up to 20 miles an hour
gespac
Car: Nissan Maxima 2004
My car Nissan maxima 2004, starts , engine sounds excellent, but on acceleration the car does not drive up to 20Miles/hour. Can someone help me please
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Welcome to NICO.
The car is either in limp mode or the transmission is shot or maybe something else. Is the CEL on? Does it rev up to high RPM yet run at run low speed (transmission slip) or the RPM is limited to 3000RPM or less (limp mode)?
gespac
The check engine light is on.. it does not reverse to high RPM.. It runs at low rpm and also reverse at low rpm. the RPM does does not fire more than 2 on acceleration.
tigersharkdude
Car: 1999 Nissan Maxima
Check those codes.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
Followv "tiger's" suggestion and get a free scan from Autozone and the likes. Get a prinout of the fault code as it will help you isolate the problem. Most likely the car is in 'limp' mode (fail-safe) which can be due to defective sensor(s) - MAF, crankshaft/camshaft, coolant temp, throttle position, etc., or worse, a bad ECU.
