Car starts, but won't idle!
300max
Car: 1995 240sx ka-t 1997 Maxima SE
Enthalpy ECU w/ 550's Z32 MAF
I finally got It started, it ended up being the battery and a MAF grounding issue.
However when started the rpm's go up to about and then start fluctuating between 1500 and 2000. After about a minute the rpms begin descending, getting to around 600-700. The engine then struggles at that point sometimes shooting up to 2000 rpms before eventually descending and stalling out. Total time is anywhere between 3-5 minutes.
Any ideas?
240SicknessX
Car: 96 240 SE
umm, are you keeping it running with giving it throttle? jookmasta had a simalar problem with the car not ideling at all, his solution was a blown off IC coupler. check your IC piping maybe.
troll's 240sx
Make sure your MAF wiring is right. The 12 volt and 5 volt reference wires not switched.
