vipercon64 »
https://forums.nicoclub.com/vipercon64-u89867.html
Mon Mar 17, 2008 2:57 pm
I had this problem Happen to me on first startup i checked a combination of things and one of them fixed it, check for a vac leak also after i detirmined that that was only half the problem my O2 Sensor was bad youll know it because itll crank up and run but itll be really rough and the only way to get above 3kl is to ease on the gas but it just dumps fuel at start up this is the reason for the blue smoke it acted as if it was like a bad tps because it would respond at wierd throttle angles and ran really rough when i gave it too much gas, try the O2 and check for vac leaks thats the cheapest way to start i dont think it will be a bad MAF. The only reason for blue smoke is too rich gas, turbo oil leak from bad seals and bushings,or a bad ring. but if its white smoke and you have low coolant and theres water in the oil , the head gasket is blown then. Check compression if you think its the head gasket it usually blows between cylinders 1&2. Good Luck
