PMan_S13 »
https://forums.nicoclub.com/pman-s13-u3715.html
Mon Jul 12, 2004 5:52 pm
Describe more in detail how it's not running right. There are a lot of ways to make a motor run bad or not at all. (Trust me I know!)
But things I have seen and had trouble with myself.
-AFM check that it isn't screwed. Disconnect and start. If it runs the same as before you have a bad AFM.
-injectors/ignition disconnect each injector one at a time while running. If it does NOT get worse when you disconnect one, you have a cylinder not firing. Check injectors,plugs,wires,coil.. anything fuel and ignition related.
-vacuum lines/leaks These suck. If you have a boost gauge it should be simple enough to tell if you have one or not. It will show little vacuum and be sluggish. Also make sure the source lines for the idle control stuff is all down stream of the AFM and hooked up well.
-TPS sensor. If you happened to move it somehow, the car will not even TRY to idle. The only time the ecu allows idling is at no throttle. If you're sensor got shifted, the ecu thinks you are giving it gas, when actually the TB is closed = motor won't even try to idle, just dies.
That's all I got without more info. Good luck
