encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Mon Aug 16, 2004 8:02 am
Alright, I tweaked and tuned today, no leaks, unfortunately. I haven't popped the valve cover, but here's the weird thing:
My girlfriend decided to go around the block, so I floored it. It slowly accelerated as described, and I noticed it was hitting full boost about 3300rpm, but still slow acceleration until about 4400 rpm where the car lurches forward and throws you in the back of the seat, it's fast. I am hitting about 9-10psi on my t3/t04b turbo.
It's fast, and works great above 4400rpm, below that it is the slowest thing I have ever driven.
So since I'm holding boost I assume no boost leaks, but there is no low end, even at full boost or partial boost below 4400rpm, what could be causing this? The cams can't be *that* extreme to only allow top end power, can they? It's almost dangerously low power, like you can't do anything.
