mrsideways »
https://forums.nicoclub.com/mrsideways-u48577.html
Wed Jul 04, 2007 3:29 pm
yea, sorry it has to idle, slipped my mind i work a lot of late nights, lol. i remember you said you played with the timing a little and got it to start, but no idle, see if you can do the same thing to get if goin better, or is that the best it would get?i know there is a write up in the how to section (just found it) giving all the steps like the diagram i have ( got it from ALL DATA.com) sounds like you did everything rite, by TDC it should run but like crap. maybe it could be that you just need to play with the dis. a little more to see if you could get an idle. once once it starts to idle, rotate it a little to see if you can get it set between 650-750rpms that should be really close to correct timing. i hope this helps you fix it, it could be a number of things keeping it from running, like iacv, tps, egr valve. but it sounds to me that its probally just the timing being off, just turn the dis. a little both ways to see if it will get any better.
