Car stalls under low throttle & heavy load (uphills)
myRed240
Car: '95 Nissan 240SX with a KA-T!
'07 Audi A3 2.0T DSG
'11 G37S Sedan
Ok guys, I've been battling this problem for some time now:
When driving up hills at low throttle my car hesitates and more often than not it stalls upon release of the throttle. The idle is near perfect, except for a cyclic hesitation (rpm drops by 100 max)
Under any other loads the car runs nearly perfect, a/f's are spot on with the occasional fluctuations . I thought changing the plugs would help and it did, for a day.
I asked everyone on this forum to look at my plugs to evaluate whether I was running rich/lean/stoich. Most everyone here said the plugs looked good(which was my impression).
At idle Vacuum ~ 19.8-20.5a/f~ 14.7-17
Besides a boost leak, can an exhaust leak cause this? Occasionally the bolts from turbo to dp loosen up, but tightening them doesn't completely
My set-up:
Auto TrannyEnthalpy tune Walbo fuel pump555ccZ32 MAFBKRE7 gapped to ~.033GReddy RS bov (recirc'd with largest fitting)AMS GT32JGS manifoldAEM widebandAEM Truboost controllerAEM oil pressure gaugeZ32tt fuel filter
Input?
Suggestions?
Questions?
-Alex
frsh13
Car: 1991 240sx coupe
Do you have the bov on the cold pipe or the hot pipe? How do you have your IACV hose routed? And do you have a fuel pressure regulator?
myRed240
'11 G37S Sedan
BOV is on hot pipe. IACV hose is right next to the throttle body. No fpr.
