Car stalls at hard decceleration on 1st.
ztunelover
Car: 1995 Nissan 240sx
ok so i was on first gear and i deccelerated hard in my 1995 240sx le. and right before stopping i hit the clutch. and then outta nowhere the engine stalls. im going to be tracking the car this summer, so i really need to diagnose this problem and fix it. help and advice would be much appreciated. Thank you.
i believe the main reason is fuel starvation under hard decceleration. what would i need to do to fix this? better pump(walbro)? fpr?
samxini
Car: '95 240sx w/Kouki conversion
Check you IACV, same deal with mine anyways, I have to roll to a stop almost.
ztunelover
thats when it does that. its really annoying. thanks ill check it out.
rob912
Car: 91 240 rb20
how low are you letting the rpms drop before you push in the clutch?and at what rpm is it stalling?
ztunelover
1200-1400. and revs drop to idle after i pop the clutch in and then it just stops. at first i thought it was me, but then after it happened again i realized nope definitely not me.
dc1984
Car: 93 240sx/98 180sx blacktop sr20det :RIP/ 93 jeep grand cherokee
i doubt its ur fuel pump, wouldnt make sense for it to run fine during acceleration and then not work under decel.
u turboed with bov?
ztunelover
bone stock ka24de. no i was wondering fuel starvation under hard decceleration. the s14 brakes suck so i was wondering how that was even possible.
dc1984
what im getting at is that your fuel pump is delivering constant fuel. ur acceleration and deceleration is not going to change how much fuel the fuel pump is pumping. now, if ur fuel pump is delivering enough fuel under hard acceleration then there is no reason for ur pump to not be delivering enough fuel under deceleration (ur car uses more fuel under hard acceleration then under deceleration). so, the problem lies elsewhere.
any luck with the iacv?
ztunelover
didnt get around to checking it. check back after april 25th. my final exams should be done after that so i should have all the time in the world to check up on it.
tercel drifter
Car: sr20det s13
Not your fuel pump, as previously mentioned scan your iacv of if you can find a 240sx manuel there should be a section on sensors and how to test them and all you'll need is the mechanic's best friend aka multimeter and you'll find out if it's good of if it's bad.
ztunelover
perfect ill check it out on the 25th. thanks.
