car sounds like a diesel
goeatpaiste
Car: 1984 300ZX Turbo, 1988 Celica Alltrac Turbo, 1988 GSXR-750 built to the tits.
I have a 90 240 SE and so i hear an obnoxious tick from the engine which sounds liek a valve tap. ive checked the lifters and they all appear to be ok. i pulled em off and they all go in and out good and smoothly. i did a compression check and all cylinders are around 150 plus or minus 5 psi. The noise began after i changed the timing chain. it made the noise before briefly for a while before i changed the chain, which is why i changed it. after the change the noise was permanent tho, and i have driven 3000 miles since then. there has been little noticable performance loss (slight but not much) and the car seems to drive and idle fine. there is a slight miss at steady rpms when free revving. any ideas guys?
could it be a pcv valve? i should just replace it. i have tried lifter conditioner stuff, engine cleaner at the oil change, and i just want the stupid thing to shut the hell up. it sounds like it is comin from # 3 or 4 cylinder top end
what could it be? could a valve have a tick even tho there is good compression?
thanks in advancestevo
nismoracingsx
Car: 1993 White 240sx Coupe
hi there, did you replace you timing chain tensioner when u did the chain? maybe its your chain rattling real bad??
kpc_0721
Car: 1991 240sx hatchback
Yea I seem to be having the same problem, did u check all your valves to see if you may have fked one up? Im pulling my valve cover off tonight and seeing if I can see anything wrong with it without having to pull everything apart hopefully. Anything special needed to pull the lifters off or anything I might wanna know that will help if I decide to try lol?
goeatpaiste
well it was easy to get the lifters off, but you need a torque wrench to reinstall them. my tensioner is brand new and it is not the chain making noise. i wish my car would shut up but its hard to fix it when there are only symptoms but no known problems
lofapoo
Car: Toyota sedan
http://youtube.com/watch?v=hZTUIXqb0Lk
Does it sound anything like this?
Check your exhaust manifold bolts and gaskets.
The two bolts and two studs on the front half of the manifold closest to the front of the car were missing, causing my gasket to fall down and cause a terrible leak at the manifold.
The video was when the problem was at it's worst. I drove around for a few years (believe it or not) with the ticking thinking it was the lifters, **** did I feel stupid after that.
WWJD
man I bet your car drove like crap. lol
goeatpaiste
dam it does sound just like that. ima check it out, for i suspected some kind of exhaust leak because my car got louder afterward. if this is it i am goin to crap my pants, i will chekc tomorrow
hope your right and thank you very much for the help. this is my 2nd 240sx. its my first ka24e though, as my 91 had an all motor ka24de which was rebuilt for turbo. i personally like this sohc better minus the noise haha
thanksstevo
lofapoo
Car: Toyota sedan
Single cams are for the dedicated, and sometimes dedication requires ear plugs, cause they are not exactly quiet motors :P
Work horse, baby. Good luck
