kouki_hmongster »
https://forums.nicoclub.com/kouki-hmongster-u99620.html
Wed Apr 01, 2009 7:45 pm
White smoke can mean that you are running rich, does it smell like gas? if it smells like burnt oil then it can mean that you did your oil feed line wrong, shouldnt have any kink since it's gravity feed back to your oil pan. (should be black smoke if burnt oil) or could be bad turbo.
You need to state what your set-up is and more detail on what you're using to control fuel so that we can further assist you. such as injector size etc... GL
EDIT: i meant oil return line, not feed line
Modified by kouki_hmongster at 10:47 PM 4/2/2009
