Car sits lower on the driver side rear than on the passenger side?
nelsan92
Car: 1992 s13 work in progress
I just installed a set of Eibach Pro-kit springs and AGX's along with an ES Hyperflex Master kit, and had the car aligned afterwards. The car rides awesome. I mean, it tracks straight, doesn't pull to the left or right, and has NO slop. But the driver side rear sits about 3/4 to an inch lower than the passenger side rear! If any of y'all have any input on how I might be able to resolve this issue I'd greatly appreciate it.
gumby74
I had/have the same issue. It was most noticeable with a full tank of gas, though my height difference was closer to 3/8".I blame the weight of the exhaust. I have since balanced out the height with coilovers. Probably not the best way to handle it but, eh what are you gonna do?
94_240sx
Car: 94_240SX
gumby74 wrote:I had/have the same issue. It was most noticeable with a full tank of gas, though my height difference was closer to 3/8".I blame the weight of the exhaust. I have since balanced out the height with coilovers. Probably not the best way to handle it but, eh what are you gonna do?
It's called gangsta lean. Same here. I had exact same issue, and it was about 4/3" difference. I also balanced out with coilovers. It felt good when it sat even finally.
