Toddles82 »
https://forums.nicoclub.com/toddles82-u7840.html
Mon Nov 22, 2004 11:17 am
I had a similar problem to yours, but I never found a solution. I searched high and low and this thread has every answer that I came up with. I took it to the dealership and one dealership said I had a bad ECU (WTF???) and the other said it was a coolant sensor and/or the AIV reed was bent (tho they never took anythign apart).
It has sense stopped surging, but it only did it when it was warm. I also had the electrical problems mentioned above.
Here's what I've come to.
I think that the wire solution is a very viable cause to this b\c the previous owner had a sunroof installed and did a ****ty job of it, so I checked that out. I would check yours for any previous installations of anything (cell phone, alarms, stereo, java machines (could have been on pimp my ride, you never know)
Last, I believe this to be very very realistic. My car has 110,000 miles on, and probably the same factory knock sensor. Sometimes the car had no power (press the throttle go no where...BAM SURGE FORWARD....back to normal) I've heard the knock sensor can make this happen.
1.) check for previous installs.2.) check grounds on your motor.3.) Consider replacing the coolant sensor temp and/or the knock sensor.
