Car shuts off once i depress the clutch after drifting? ka24
aznjesus44
Car: 89 240sx hatch SE
Hey, i have a ka24de with brian crower 264 cams. I got the car running about 2 weeks ago. Just yesterday i started having my car shut off on me after i would drift around and beat on the car for about 15 seconds. It would shut off once i pushed the clutch in and slow down. My car doesnt shut off if i beat on the car going in a straight line. After it would shut off on me, the car would have a hard time cranking back up and requires me to hit the gas and raise the rpm's way up.
P.S. the problem started occurring right after my i got my diff welded. I dont know if these two things could affect each other.
poshatch
Car: p.o.s. 1990 240sx hatch
eeeeekkkkkkk!!
this story look ALL BAD from my POV. getting 240sx and a welded diff and beating on the car drifting around...happens way too often it seems
now i think more info is required here so did it just cut off or did it rev down and not stay at idle..pass it and die?
im gonna guess its your cams if everything else is functioning ok...any significant vacuum leaks or significant grounds not being grounded? check battery too
aznjesus44
It revs down slowly, it isnt a sudden cut off.
poshatch
well thats good news. sudden would be bad
and it only happens when your driving it hard you say?
aznjesus44
yes, it doesnt always do it though but it does alot of the time.
poshatch
check idling system
